Indy may not be Keith Black but at least their studs are ARP The cross bolts are marked "DB". Would they matter as much?
Why do the studs only go halfway through the nuts? If that cap is all the way down (which it appears to be) those studs are at least 3-4 threads too short, no matter whose name is on them.
Free advice and worth every penny... Factory trained Slinky rewinder.........
