Explains why Utah has less than 1% confirmed case fatality ratio while KY has 4.98%
In the article accompanying the map:
"In collaboration with Microsoft Healthcare NeXT and CareJourney, Dartmouth Atlas has also issued data about the regions in the U.S. with Medicare beneficiaries over the age of 65 who have two or more chronic conditions—the people most vulnerable to developing severe cases of COVID-19."
I believe the map is color-coded to show general public over age 65 with 2 or more chronic conditions, AND NOT (covid) patients with two or more underlying conditions. I believe the writers are inferring that those areas could see high death rates among that population should covid get a toe-hold in those commnities.
Pretty sure that is the exact point he was making when he posted it.
He then highlighted Utah because the map shows few people over 65 with 2 conditions... Then I pointed out that W.V. is loaded with old people with at least 2 chronic conditions... yet has few covid cases.
NY, NJ & PA are seeing high death rates, in part because all 3 of them decided to send covid patients back to the nursing homes. Apparently it wasn't just NY that did it... they just did it 1st. 25% of NY deaths are in nursing homes... in PA the figure is currently 65%... I didn't see a Nursing Home % figure posted for NJ yet, but it's likely at least as high as NY
