Well I see the leader of the tinfoil hat army has showed up. Did you know that the entire state of NJ is basically a dumping ground for C8? You boys can fight it out among yourselves, I'm heading for the mountains. Hopefully I'll see you all on the other side of this.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
