Originally Posted By TomsCharger70
Here is another question about nitrous I have been thinking about. Might sound dumb, but I just can´t get myhead around on how it works..
So... When you add nitrous, you also have to lower the engines timing. Ok, so this is what Im having trouble understanding.
Lets say you take out 6 degrees of timing from a N/A engine, that would lower the engines horsepower by X amount. So lets say lowering the timing by 6 degres lowers the engines horsepower output by 100hp. So if you add 150hp of nitrous, wouldnt that just give you an added 50hp???
How does this work?
Thanks for taking the time to answer my question.
/Tom
Nitrous speeds up the burn .. That simple. Some engines need more retard because of the quench, cam etc. retard slows the burn rate, im sure Monte will have a better explanation , more detailed
....BAD A$$ STREET CAR.....
