Re: Moving Battery to trunk, do you have to have a shut
[Re: dave571]
#193326
01/16/09 08:14 AM
01/16/09 08:14 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
ok i've been warned at the track already, how should i run the wires 'cause i don't think the instructions that came with the switch to just interupt the pos batt cable with the switch will be adequet? do i just also run the alt batt wire back to the switch then back forward to the factory batt term on the firewall to basically interupt this circuit with the switch as well? again, sorry i'm a bit thick on this
The easy way, with no relays required.....
Disconnect the factory alternator(heavy b+) output wire from the alt.
Run a heavy wire/cable from the alt B+ to the battery positive terminal in the trunk (or the SAME side of the switch that the battery positive is on)
In review....2 pole switch. One side has the alt B+ wire, AND the batt pos on it. The other side has the cable that goes up to the starter solenoid,(where the factory pos wire used to go)
It's really that simple.
No relays, only one extra wire, it'll shut the car off every time, and pass tech every time.
The rules state that electrical function must cease, and it all does. ![](/ubbthreads/images/graemlins/beer.gif)
Think of it this way. The car needs B+ to run. The batt OR the alt can provide B+ By putting them both on the SAME side of the switch, you isolate them both from the rest of the car when you throw the switch. The other benefit, your ammeter is now bypassed. no chance of melting anything.
Exactly like I said above. ![](/ubbthreads/images/graemlins/beer.gif)
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
Entire Thread
Moving Battery to trunk, do you have to have a shut off
WadeMetzinger
01/14/09 07:18 PM
Re: Moving Battery to trunk, do you have to have a shut off
tonycpe
01/14/09 07:22 PM
FlyFish
01/14/09 07:30 PM
dave571
01/14/09 07:36 PM
maximum entropy
01/14/09 07:38 PM
MoparforLife
01/14/09 07:39 PM
Triple Threat
01/14/09 07:41 PM
WILD BILL
01/14/09 10:16 PM
AndyF
01/14/09 11:09 PM
Aspen7695
01/15/09 02:35 AM
racealittle
01/15/09 02:48 AM
superwrench
01/15/09 03:07 AM
RobX4406
01/15/09 03:12 AM
Leadfoot
01/15/09 03:23 AM
MoparforLife
01/15/09 03:30 AM
Post deleted by Defbob
01/15/09 03:32 AM
dirtybee
01/15/09 04:06 AM
Leadfoot
01/15/09 04:11 AM
dirtybee
01/15/09 04:13 AM
RobX4406
01/15/09 04:38 AM
AndyF
01/15/09 06:22 AM
smokinwoody
01/15/09 07:16 AM
MoparforLife
01/15/09 11:36 AM
WILD BILL
01/15/09 02:13 PM
Mike Miller
01/15/09 02:32 PM
Stewart
01/15/09 04:32 PM
fasteddie
01/15/09 09:31 PM
69CHARGERMD
01/15/09 10:13 PM
RobX4406
01/15/09 10:20 PM
69CHARGERMD
01/15/09 10:32 PM
MoparforLife
01/15/09 03:13 AM
smokinwoody
01/15/09 10:55 PM
Stewart
01/15/09 11:15 PM
fasteddie
01/15/09 11:48 PM
PLUM BAD
01/16/09 12:38 AM
69CHARGERMD
01/16/09 01:09 AM
SRT8Challenger
01/16/09 01:31 AM
VernMotor
01/18/09 12:58 AM
383man
01/18/09 02:58 AM
fasteddie
01/18/09 03:12 AM
NTOLERANCE
01/18/09 04:49 AM
MoparforLife
01/18/09 01:53 PM
smokinwoody
01/18/09 02:53 PM
NTOLERANCE
01/18/09 03:00 PM
smokinwoody
01/18/09 03:05 PM
VernMotor
01/18/09 03:44 PM
RobX4406
01/18/09 06:30 PM
NTOLERANCE
01/19/09 01:30 AM
dirtybee
01/16/09 12:56 AM
smokinwoody
01/16/09 02:33 AM
69CHARGERMD
01/16/09 03:01 AM
smokinwoody
01/16/09 03:26 AM
RobX4406
01/16/09 03:48 AM
dirtybee
01/16/09 04:29 AM
smokinwoody
01/16/09 04:38 AM
dirtybee
01/16/09 04:49 AM
smokinwoody
01/16/09 04:56 AM
RobX4406
01/16/09 04:59 AM
Von
01/16/09 05:13 AM
smokinwoody
01/16/09 05:19 AM
Von
01/16/09 05:26 AM
RobX4406
01/16/09 05:35 AM
smokinwoody
01/16/09 12:07 PM
dave571
01/16/09 06:54 AM
MoparforLife
01/16/09 12:14 PM
Mopar_Ray
01/16/09 12:21 PM
SRT8Challenger
01/16/09 12:43 PM
dirtybee
01/16/09 01:23 PM
69CHARGERMD
01/17/09 11:52 AM
smokinwoody
01/17/09 12:34 PM
MoparforLife
01/17/09 02:05 PM
Mopar_Ray
01/17/09 02:45 PM
67Satty
01/17/09 03:14 PM
MR_P_BODY
01/17/09 03:32 PM
Pacnorthcuda
01/17/09 04:15 PM
69CHARGERMD
01/17/09 04:17 PM
451Mopar
01/17/09 05:03 PM
RobX4406
01/17/09 05:14 PM
69CHARGERMD
01/17/09 05:25 PM
RobX4406
01/17/09 05:41 PM
jinxy
01/17/09 06:17 PM
MoparforLife
01/17/09 06:31 PM
RobX4406
01/17/09 06:42 PM
MoparforLife
01/17/09 07:11 PM
RobX4406
01/17/09 07:22 PM
MoparforLife
01/17/09 07:57 PM
RobX4406
01/17/09 08:03 PM
MoparforLife
01/17/09 09:33 PM
69CHARGERMD
01/17/09 11:08 PM
MoparforLife
01/18/09 12:24 AM
Mopar_Ray
01/18/09 12:00 AM
juicedcuda
01/17/09 07:27 PM
RobX4406
01/17/09 07:32 PM
juicedcuda
01/17/09 07:36 PM
Gavin
01/17/09 07:42 PM
