Re: Moving Battery to trunk, do you have to have a shut off
[Re: NTOLERANCE]
#193362
01/18/09 10:53 AM
01/18/09 10:53 AM
Posts: 12,339 somwhere
smokinwoody
somwhere
My disconnect switch had 4 terminals on it. One set is large for the main battery cable, and one set is small for the alternator batt wire. I run a smal jumper from the battery larger terminal, to the small terminal. The other small terminal goes to the alternator.
No relay needed.
I hope those little terminals are rated for more than 30 amp..most alternators put out at least 60A and average is 80A...usualy those smaller terminals would be reserved for the ignition which is a great idea...I use mine that has 2 poles for ignition and I use a solonoid for disconecting the power from the alternator so I dont have any HOT wires leaving the Trunk/battery area...and when the switch is OFF...its all OFF..
there are other ways Im sure...I believe there maybe a switch that has the two poles rated for the higher amperage
Entire Thread
WadeMetzinger
01/14/09 07:18 PM
tonycpe
01/14/09 07:22 PM
FlyFish
01/14/09 07:30 PM
dave571
01/14/09 07:36 PM
maximum entropy
01/14/09 07:38 PM
MoparforLife
01/14/09 07:39 PM
Triple Threat
01/14/09 07:41 PM
WILD BILL
01/14/09 10:16 PM
AndyF
01/14/09 11:09 PM
Aspen7695
01/15/09 02:35 AM
racealittle
01/15/09 02:48 AM
superwrench
01/15/09 03:07 AM
RobX4406
01/15/09 03:12 AM
Leadfoot
01/15/09 03:23 AM
MoparforLife
01/15/09 03:30 AM
Post deleted by Defbob
01/15/09 03:32 AM
dirtybee
01/15/09 04:06 AM
Leadfoot
01/15/09 04:11 AM
dirtybee
01/15/09 04:13 AM
RobX4406
01/15/09 04:38 AM
AndyF
01/15/09 06:22 AM
smokinwoody
01/15/09 07:16 AM
MoparforLife
01/15/09 11:36 AM
WILD BILL
01/15/09 02:13 PM
Mike Miller
01/15/09 02:32 PM
Stewart
01/15/09 04:32 PM
fasteddie
01/15/09 09:31 PM
69CHARGERMD
01/15/09 10:13 PM
RobX4406
01/15/09 10:20 PM
69CHARGERMD
01/15/09 10:32 PM
MoparforLife
01/15/09 03:13 AM
smokinwoody
01/15/09 10:55 PM
Stewart
01/15/09 11:15 PM
fasteddie
01/15/09 11:48 PM
PLUM BAD
01/16/09 12:38 AM
69CHARGERMD
01/16/09 01:09 AM
SRT8Challenger
01/16/09 01:31 AM
VernMotor
01/18/09 12:58 AM
383man
01/18/09 02:58 AM
fasteddie
01/18/09 03:12 AM
NTOLERANCE
01/18/09 04:49 AM
MoparforLife
01/18/09 01:53 PM
smokinwoody
01/18/09 02:53 PM
NTOLERANCE
01/18/09 03:00 PM
smokinwoody
01/18/09 03:05 PM
VernMotor
01/18/09 03:44 PM
RobX4406
01/18/09 06:30 PM
NTOLERANCE
01/19/09 01:30 AM
dirtybee
01/16/09 12:56 AM
smokinwoody
01/16/09 02:33 AM
69CHARGERMD
01/16/09 03:01 AM
smokinwoody
01/16/09 03:26 AM
RobX4406
01/16/09 03:48 AM
dirtybee
01/16/09 04:29 AM
smokinwoody
01/16/09 04:38 AM
dirtybee
01/16/09 04:49 AM
smokinwoody
01/16/09 04:56 AM
RobX4406
01/16/09 04:59 AM
Von
01/16/09 05:13 AM
smokinwoody
01/16/09 05:19 AM
Von
01/16/09 05:26 AM
RobX4406
01/16/09 05:35 AM
smokinwoody
01/16/09 12:07 PM
dave571
01/16/09 06:54 AM
MoparforLife
01/16/09 12:14 PM
Mopar_Ray
01/16/09 12:21 PM
SRT8Challenger
01/16/09 12:43 PM
dirtybee
01/16/09 01:23 PM
69CHARGERMD
01/17/09 11:52 AM
smokinwoody
01/17/09 12:34 PM
MoparforLife
01/17/09 02:05 PM
Mopar_Ray
01/17/09 02:45 PM
67Satty
01/17/09 03:14 PM
MR_P_BODY
01/17/09 03:32 PM
Pacnorthcuda
01/17/09 04:15 PM
69CHARGERMD
01/17/09 04:17 PM
451Mopar
01/17/09 05:03 PM
RobX4406
01/17/09 05:14 PM
69CHARGERMD
01/17/09 05:25 PM
RobX4406
01/17/09 05:41 PM
jinxy
01/17/09 06:17 PM
MoparforLife
01/17/09 06:31 PM
RobX4406
01/17/09 06:42 PM
MoparforLife
01/17/09 07:11 PM
RobX4406
01/17/09 07:22 PM
MoparforLife
01/17/09 07:57 PM
RobX4406
01/17/09 08:03 PM
MoparforLife
01/17/09 09:33 PM
69CHARGERMD
01/17/09 11:08 PM
MoparforLife
01/18/09 12:24 AM
Mopar_Ray
01/18/09 12:00 AM
juicedcuda
01/17/09 07:27 PM
RobX4406
01/17/09 07:32 PM
juicedcuda
01/17/09 07:36 PM
Gavin
01/17/09 07:42 PM
