How many times have you gotten into the car and realized the switch is in the off position? I put the switch on the driver side rollbar tube that runs from the top of the main loop to the rear of the car. Then a long rod or a chute cable can be mounted right above your head so you can also operate the switch from inside the car. If you have a problem on the track, your the first one there, so you can kill your own power.
