Re: Moving Battery to trunk, do you have to have a shut
[Re: RobX4406]
#193330
01/17/09 07:52 AM
01/17/09 07:52 AM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Doug, I'm guessing the mad electric wire kit comes with the less expensive relay. I've used some of the cheapest relays ever and never had an issue with the relays. I ALWAYS carried a spare.
I generally wire it like the first diagram and use two relays. One for the starter and wired like the diagram. The second I remove the alt wire from the starter relay in the first diagram and run it like the 3rd diagram with the s605.
Once the car starts, the only two hot wires to the front run to the starter relay lug and the alternator wire.
The starter wire/cable is only hot when the key is in the start position.
Hope that helps. It's a bit of a hybrid of the two as I don't like any of the three on a standalone basis. My thinking is that once you throw the cut off, everything beyond the switch and relays should be dead. Keep anything hot contained to a small area in the trunk.
Revised the way I like to wire them up.
Rob,,,, Is there an advantage to running TWO relays,,,, Wouldnt the pic below be OK ? Sorry,,,i am learning here,,,, Seems like the same thing ?? (ps,,in your pic,,you have 2 "different" relays,,one a "ford" the other a sBorg ? (is there a difference,,),,again forgive my electrical knowledge,,
Entire Thread
Moving Battery to trunk, do you have to have a shut off
WadeMetzinger
01/14/09 07:18 PM
Re: Moving Battery to trunk, do you have to have a shut off
tonycpe
01/14/09 07:22 PM
FlyFish
01/14/09 07:30 PM
dave571
01/14/09 07:36 PM
maximum entropy
01/14/09 07:38 PM
MoparforLife
01/14/09 07:39 PM
Triple Threat
01/14/09 07:41 PM
WILD BILL
01/14/09 10:16 PM
AndyF
01/14/09 11:09 PM
Aspen7695
01/15/09 02:35 AM
racealittle
01/15/09 02:48 AM
superwrench
01/15/09 03:07 AM
RobX4406
01/15/09 03:12 AM
Leadfoot
01/15/09 03:23 AM
MoparforLife
01/15/09 03:30 AM
Post deleted by Defbob
01/15/09 03:32 AM
dirtybee
01/15/09 04:06 AM
Leadfoot
01/15/09 04:11 AM
dirtybee
01/15/09 04:13 AM
RobX4406
01/15/09 04:38 AM
AndyF
01/15/09 06:22 AM
smokinwoody
01/15/09 07:16 AM
MoparforLife
01/15/09 11:36 AM
WILD BILL
01/15/09 02:13 PM
Mike Miller
01/15/09 02:32 PM
Stewart
01/15/09 04:32 PM
fasteddie
01/15/09 09:31 PM
69CHARGERMD
01/15/09 10:13 PM
RobX4406
01/15/09 10:20 PM
69CHARGERMD
01/15/09 10:32 PM
MoparforLife
01/15/09 03:13 AM
smokinwoody
01/15/09 10:55 PM
Stewart
01/15/09 11:15 PM
fasteddie
01/15/09 11:48 PM
PLUM BAD
01/16/09 12:38 AM
69CHARGERMD
01/16/09 01:09 AM
SRT8Challenger
01/16/09 01:31 AM
VernMotor
01/18/09 12:58 AM
383man
01/18/09 02:58 AM
fasteddie
01/18/09 03:12 AM
NTOLERANCE
01/18/09 04:49 AM
MoparforLife
01/18/09 01:53 PM
smokinwoody
01/18/09 02:53 PM
NTOLERANCE
01/18/09 03:00 PM
smokinwoody
01/18/09 03:05 PM
VernMotor
01/18/09 03:44 PM
RobX4406
01/18/09 06:30 PM
NTOLERANCE
01/19/09 01:30 AM
dirtybee
01/16/09 12:56 AM
smokinwoody
01/16/09 02:33 AM
69CHARGERMD
01/16/09 03:01 AM
smokinwoody
01/16/09 03:26 AM
RobX4406
01/16/09 03:48 AM
dirtybee
01/16/09 04:29 AM
smokinwoody
01/16/09 04:38 AM
dirtybee
01/16/09 04:49 AM
smokinwoody
01/16/09 04:56 AM
RobX4406
01/16/09 04:59 AM
Von
01/16/09 05:13 AM
smokinwoody
01/16/09 05:19 AM
Von
01/16/09 05:26 AM
RobX4406
01/16/09 05:35 AM
smokinwoody
01/16/09 12:07 PM
dave571
01/16/09 06:54 AM
MoparforLife
01/16/09 12:14 PM
Mopar_Ray
01/16/09 12:21 PM
SRT8Challenger
01/16/09 12:43 PM
dirtybee
01/16/09 01:23 PM
69CHARGERMD
01/17/09 11:52 AM
smokinwoody
01/17/09 12:34 PM
MoparforLife
01/17/09 02:05 PM
Mopar_Ray
01/17/09 02:45 PM
67Satty
01/17/09 03:14 PM
MR_P_BODY
01/17/09 03:32 PM
Pacnorthcuda
01/17/09 04:15 PM
69CHARGERMD
01/17/09 04:17 PM
451Mopar
01/17/09 05:03 PM
RobX4406
01/17/09 05:14 PM
69CHARGERMD
01/17/09 05:25 PM
RobX4406
01/17/09 05:41 PM
jinxy
01/17/09 06:17 PM
MoparforLife
01/17/09 06:31 PM
RobX4406
01/17/09 06:42 PM
MoparforLife
01/17/09 07:11 PM
RobX4406
01/17/09 07:22 PM
MoparforLife
01/17/09 07:57 PM
RobX4406
01/17/09 08:03 PM
MoparforLife
01/17/09 09:33 PM
69CHARGERMD
01/17/09 11:08 PM
MoparforLife
01/18/09 12:24 AM
Mopar_Ray
01/18/09 12:00 AM
juicedcuda
01/17/09 07:27 PM
RobX4406
01/17/09 07:32 PM
juicedcuda
01/17/09 07:36 PM
Gavin
01/17/09 07:42 PM
