It depends on the track and how fast the car is. The local track here doesn't require an external shut off even though the rules require it. I've had my car thru tech several times and the tech guy has never been concerned about my lack of an external shut off. He looked over my trunk mounted battery closely and examined the straps that hold it down and then said I was good to go.
