What about the newer Chrysler products that come with the battery factory mounted in the trunk? I've seen them running at the track without a shutoff switch or a battery box.
Ah-Ha!!! A can of worms here???
IIRC, it's required IF you move the battery from the factory location.
No worms on the loose
