My disconnect switch had 4 terminals on it. One set is large for the main battery cable, and one set is small for the alternator batt wire. I run a smal jumper from the battery larger terminal, to the small terminal. The other small terminal goes to the alternator.
No relay needed.
I used to care but....... things have changed
