OK, I've got a silly question. Why does moving the battery to the trunk position necessitate having a cut-off switch?
I can see that having a switch to shut off power is a good safety idea. So wouldn't it also be a good idea with the battery under the hood?
What is it about moving the battery back that makes it a rule to have the cutoff switch?
