Good Lord! Some people make even the simplest things complicated and fight about it.
Call Mark at Mad electrical and he will supply you with all you need, wiring, relays, and most important, instructions.
Wire it the way he says in the supplied instructions and you will be safe and legal.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
