As Bill says, that plastic part is a baffle for your vent.I've never seen anything inside them so I'm not sure what would have blown out when you blew air in it. Possible some dirt build up?
I've attached a picture of your valve body. Looks good but the adjuster for the pressure regulator looks crooked. Is it just the angle of the picture? I've highlighted the area in red.
