Quote: Heck, Best Machine had trouble selling the 5 pairs of B1 PSO heads they did, I don't see the demand for a 5" block.
Because at the end of the day, those heads STILL bolt on a bore limited, 4.800 bore space block. If that head was cast in a 4.840 to bolt on the Indy or other 4.840 block, THEN you would have something.
Monte
The Predator heads fit your scenario? My point is Mopar people will not spend the $$$.......
