I'm sorry but no. It doen't make sense for me to make lines for every application when you can buy whatever lines would belong on your car if it has ps. The factory box does the pressure line the same way in most cases where it converts from female thread on the box to male thread. Most factory pressure lines use a female thread on the end of the hose, which is the same as the adapter I'm making.
