Quote: Yup.. Nobody seems to realize the lower shaft can be swapped from quite a few other cars & since you modding the one for the Borgeson you might as well swap the lower shaft before you cut it...
Yes, they are interchangable, however if Borgenson would just supply a proper coupler in the first place tearing into the steering column wouldn't be neccessary at all which relates to my initial comments.
You cant go back once you cut the shaft either(without a lot of work). If I want to sell my car later, I will have a harder time selling it with hacked up and/or not original parts. If I have the original box waiting to get bolted back in and it can be easily, all is good.
The Bird
Some are wise, and some are otherwise...
Say what you want, but in the end, it is what it is...
