Borgeson came out with a complete kit, but I agree that cutting the steering shaft wasn't the best solution. Rick looked at the product and had some ideas on how to improve on it. If you read the article Rick tried the box on multiple K frames from 62 to 89, some he found needed clearance grinding. It also said borgeson was working on hose adapters and if they didn't make the coupler, Rick has a machine shop that will modify yours. There is a part 2 in the next issue. This box is new and will take time for the word of mouth to spread.
