page down this pdf and see if your car is wired like the diagram shown for converting from points to electronic
www.dippy.org/upgrade/ignition.pdf
It shows the dark green wire not being used if the module is a five wire version...I need to go look for the four wire module...I have forgotten which one you have
Steve
