What is the voltage reading on the positive battery terminal clamp...not the battery post, but the clamp, when you crank the car over? And, then on the actual post, not the clamp...when cranking?
I measured the voltage reading on the positive battery terminal clamp while cranking as requested, it was approximately 10.9 volts.
I cannot measure it at the post while cranking because I am by myself and cannot figure out a way to rig something to just touch the post and nothing else without holding it.
I also measured it at the positive clamp at rest and it was about 12.8 volts.
