I didn't go back and read everything but I see you changed the switch because this was happening , what did you change or modify before this started or did it all of a sudden happen ?
I did not change or modify anything before this was happening.
I just hadn't started the car in a few months.
When I went to start it after a few months, it was having this problem, but I got it started.
When I went to drive it, I warmed it about for about 15 minutes, then when I was driving it for a about a mile, the car stalled.
Couldn't get it restarted ( meaning when I turned the key it didn't even crank).
So I had it towed back to the house and have been working on it ever since...
So is the fact that it stalled AND having the starting issue , related??
I suspect it is, but not sure what it points to, hence me replacing everything I could think of, including the ignition switch.
