You have a dual side resistor and the start side is open. Pull the spade connectors off the resistor and put the two wires that are on the top on the bottom and vice versa.
Now if your car starts while the key is in the start position and shuts down in the run position.....you have found the problem.
Not sure where ( what part) you are talking to pull spade connectors from, can you please explain further, thanks.
