Any place like an intake bolt or anything you get a good connection to on the engine...if you can connect the positive probe to the cable clamp and scratch a clean spot on an engine bolt with the ground probe, then hold the probe to that spot while you crank the engine with a screw driver on the starter relay....
Some day, I may yet buy a remote starter button
Steve
