It did not start with key in run position and jumped at starter relay
Just to make sure you guys aren't getting crossed up. Is jumping at the starter relay bypassing the same wiring as if you jumped it on the actual starter?
You state that it didn't start when jumped at starter relay, but he asked you to jump at the starter.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
