Let see you benefit from these tactics for years and never open your mouth. It gets you a championship and your own ride and now that it bites your brother in the a$$ you want to complain??? Sorry it does not work that way....it reminds me of the politicians and the Iraq....cant have it both ways or you are a hypocrite.
Anyone that has a brain bigger than a gnat knew exactly what was going to happen. NHRA did not say it was a good run they just said there was not conclusive evidence to over turn the run....does that surprise anybody??
You could say the same thing about the FC final. Amazing that Roberts car blew up before the finish line huh?? Can you say inconclusive proof....imagine that!
There is no way to stop it unless you limit each car owner to one car per class.....do that and you will not have enough TF or FC cars to race. It is here to stay, so accept it or don't watch because NHRA can/will not stop it.
"Turbo will be easiest, and at the HP level will also be easiest on parts. Spend the money to do it right, and you can build a 500 HP street motor that will live a long and happy life, and probably with a very basic short block."
Those words must have left a bad taste in his mouth!
