It sounds like it it was the original cam that came in his engine in '69.......
Quote: Wayne, does Ray Barton grind SS/AA cams and advertise lift and duration on his website? Does Dan Davorak grind Max Wedge/Stock eliminator cams and advertise on his site? How about Tri City Comp. no advertisement there either? Maybe Don Little??? No Not on his Homepage???Maybe thats the reason Bob doesnt post the numbers???
That's a good point, but those guys, or their customers, aren't recommending those "race" cams for ANY other kind of race motor either.......
I honestly believe the a small solid flat tappet or roller cam with similar duration as a stock cam, but with more lift, will make more power and idle just as well as a stock camshaft........More lift is one of those things that does not hurt power, it only helps if the heads flow enough to use it.......
