Maybe we should all confess to screwing an engine up...
Uhh hi my names Chad and I've broke some stuff, the 451 in my Demon has been down twice since its build, first time not sure why it bent a rod but it did it was tight from get go. New builder and much free'er second time around had ran great then it wiped a cam lobe. It is down now being fixed. The cam lobe happened 5 years ago, someone told me it was likely an issue with removal of zinc. Was it
but it's getting fixed finally. Hope it doesn't happen again.
