It blacked the crank. It was tight or had no oil. Stacked a bearing and then broke rod bolts.
All the mains look fine except #4......need to figure of why THAT is and you might discover why that rear journal had no oil, or at least less than rest.........BUT.....ALL the rods were tight or had low oil volume. The pictures tell the story
