A machinest/Dyno operator looked at everything and took some measures. Said the bearings show heat. Had pressure but no flow. I don't understand. I did find the rear main cap cracked in two places so the block is junk. I'm putting this behind me. Thanks for trying to help. I will never modified another engine block oiling system. Promise
