correct on the bearing orientation. opened up all 1/2" and 5/16" oil gallery. plugged dr oil gallery on #1 main. this was done before the block went to the shop and it did get a cleaning there. their is a plug in the large oil gallery under the rear cap. what is the proper orientation for that plug? how is it possible to have 75psi oil and not get enough oil to bearings?
