Quote: ..... I'm going to set up a degree wheel & check where the sensor is @ on TDC. The #1 pip might move over the sensor after TDC...
That's the way to do it.
Along with this pinout diagram...you just remove all the wires shown as "not used". A good general guide for making a "stand-alone" LS harness is available at:
