Quote: but sorry if i missed it but how hard would this be to make work on my two for tunnel-ram. also wasn't you going to maybe offer this in a kit some way? don't really have the money to do it right now but latter on down the road i would like to do it to my car. thanks Mopar65
Really no different on a tunnel ram....just add bungs to your manifold (can even be done with JB weld epoxy if you don't want to TIG them). You just have 2 Throttle bodies and just use the TPS and IAC on one of them.
I had originally thought about making the Crank and Cam sensor setups to sell, and the wiring harnesses. Don't know if I ever will do that or not....but I decided to just share what I've learned for now.
Maybe Redmist will make a batch of the cam sensor bushings to sell...that would make the swap easier too.
