Just a thought, blocked exhaust will cause the same problem. Old double wrapped pipes would sometimes buckle on the inside and not be visible on the outside - try running w/o exhaust if you had one on for your street test
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
