Hello all! I've So, I take it out for a test drive..NO power at all. I doubt if it would burn rubber! Seems like a slight miss out at light cruise.
I have taken out plugs. Might be a bit rich, Looked in chamber with a Snap-On bore scope, adjusted rockers ICE-EOI method 3 times Jeff
After reading all of your posts! IMO This is a bogus type thread You state above, you doubt if it will burn the tires
The combo as listed should rock. I think your mocking Moparts.
DO WHAT? Not mocking anything, just seeking advise! Jeff
