The " grey" oil is a pretty good indication of something...typical when a cam goes bad....there seems to be a lot of mysteries here....but I bet it will be something basic was missed on the build, in the end.....although it may not be admitted.... ....good luck to you though, and hope it gets fixed.
Hello! There are NO wiped lobes on the cam. I checked lift on all. They are all the same. Still looking, and I will admit if it was a build mistake. Too many wanting to know on this one! Take care, Jeff
Did you ever actually have a degree wheel on that
engine... I see you had a pic of the dot and 2 degrees
BUT did you have a wheel on it and actually measure it
Mr. P, yes, I had degree wheel on twice, and again today to check. That is what I was really thinking was wrong. But, I now think it is correct. On to more checking! Jeff
