did you re-degree it after you advanced it to make sure it only went 2 more degrees? i wouldn't assume that it was right. why not just put it back at "0" where you new it was at 8 1/2 like stated earlier and run it like that?
Hello, Yes, I did check a couple time to make sure I only went 2degs. If I am correct with my degree method and it is only 2 deg advanced from actual zero, straight dot to dot, I can't see that could possibly be causing my problem. I wouldn't think 2 deg one way or the other can cause this much problems. I have thought about moving it back to zero. I've also thought about getting another timing set and checking it against this one. Take care, Jeff
