Here is a pic of the pair I made for my Challenger. I used 2x3 tube and cut the rear to fit the contour of the rear frame back to where the frame starts to go up. Everything that touched the floor I cut through. The rear frame rails come up at an angle so I heated the rear of my connectors and tweaked them so they would follow the line of the factory frame but go straight forward to the torsion cross member.
