Another thing I found that helps once you have a bar installed is to tie the bar into the roof structure where the bar makes its bend to go horizontal,usually a short piece of tubing a few inches long welded in will make a big difference. Zip, the 3" is the vertical,cut thru the floor & weld solid where necessary
