Do you have a part number on the coil? I have some specs for some of them but need the number to see if I have the right one.
If you can supply that and do the following and post back, we might find some info on it.
1.
Disconnect everything from your ignition coil
2.
Take your DMM, set to the Ohm or continuity setting, making sure you have the range set properly
3.
Connect the DMM between the (+) and (-) terminals on your coil. Note the reading.
4.
Connect the DMM between the (+) terminal and secondary terminal on your coil. Note the reading.
5.
Connect the DMM between the (-) terminal and secondary terminal on your coil. Note the reading.
