I don't believe you will not find a spec for voltage going to the pickup coil as the ECU measures a/c voltage generated from the pulses from magnetic distributor pickup.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
