David, I found a spec of 150-900ohms thru the pickup coil (which I am going to check tonight), but I was wondering what the voltage would be coming to the pickup coil with the key at RUN just so I can confirm that too. I guess I will know if it starts up that it had enough voltage.
I have 12v going thru two of the pins at the ECU harness but only 1.85v is coming from the ECU (I think that is the source) and getting to the pickup.
Thanks for the reply,
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
