Easiest way to check is to use a jumper wire from the battery to bypass those wires. If it starts, most likely it is your problem.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
