Quote: Richard, that's a great offer. Thanks a lot. I don't plan on tackling this issue until winter time. I will keep it in mind.
That's okay, this winter, contact me and I'll help you out then. When it gets to that point, Like I offered above, I will send you a mockup case and then you can see if you will be needing to cut or not. For what it's worth, the cut and patch is not so big that you'll need to change the carpet or anything drastic like that. We simply need to raise an widen the tunnel slightly to get the front passenger side of the transmission to fit.
