Quote: The b'cast sheet holds your answer: What is the 3 digit number under ENG on line 4? What is the 2 digit number under CARB following it on line 4?
1970 N code 383s were both 335hp orange HPs with HOLLEY carbs & 330hp blue with CARTER carbs.
Ebodyseast, your buildsheet has the answers to the part number of the motor and carb.
Please post the codes so we can learn more about this odd Mopar offering of two 70 383 4bbl motors. Educate us.
