Ok did some measuring and blueprinting in my head
The rack can be moved up 4-5", but at ride height it looks like it will only have to be moved up about 3". I'll radius out the 2x4" tubing I have tacked in there for the rack and that will make plenty of room.
Mr P how did you cut and rethread your tie rods? The reason I ask is the dia of the rod is much too big to just run a die over. The only thing I can see is to remove the ball and socket from the rack and turn in a lathe.
My other question is, the drivers side has a plate with two mounting holes. There is nothing on the passenger side to mount. It's just a smooth housing. How do you mount this side?
