Quote: Your Rack is going to have to move back to take your almost maxed out inner tierod angle away. Look at your pic #4 When you turn your steering sharp left, look at the direction the outer steering arm takes.
It will swing to the rear of the car and if the rack arm is maxed out it will bend itself.
I admire what your doing but you need to put down the welder and do some more study. I dont have this rack thing down 100% myself.
Dont be like me and end up having to reposition your Rack 4 times. www.heidts.com and www.lonacreracing.com has some good info on positionening a rack.
With the A bodys you cant really get the rack exactly were it needs to be. So at best its a comprimise IMO The rack needs to be further Up and Back then you have it. But you see the problems with that no doubt. mike
Just a bump for you, to help connect some info. mike
