Quote: If the steering arms are extended 2" as Mr P suggested everything will be right on. I just don't know about welding cast to mild steel. Has anyone done this? I've welded cast to cast with ni-rod 55. But I dont know of a procedure for mild steel to cast.
Use that same rod for cast to steel
I could also use nickel filler rod and tig weld it I believe. I'll have to give airgas a call tomorrow and see what they think is best.
