Quote: Fred, can you also get a pic looking down on your steering arms.
Also from A body to B body steering arms is one longer? Also does one curve upward and curve downward?
I can get disc brakes off of a 75 volare from the junk yard for $80. Is this a good deal? This includes rotors, calipers, spindles. Not sure if the upperarms will exchange?
Years ago I used F/M body spindles on a A-body and I recall that I had to increase the size of the upper bal joint taper to fit the A-body ball joint
