Use that same rod for cast to steel
I could also use nickel filler rod and tig weld it I believe. I'll have to give airgas a call tomorrow and see what they think is best.
What steel did you use? 1045?
I cut the taper off the steering arm and trashed that
part then butt welded the mild steel to the end (with
the hole in the steel for the heim bolt) then for
safety I laid a strip of mild well over the cast and
out on to the mild . Remember you can put that outer
end at ANY point you want... if you need it up or
down... now is the time to move it so it lines up
better with the rack height
I used a hi nickle rod(I forget the number for it)
