Quote: like the poll says,b/rb rules the roost,far more big block racers.no antiquated racers here,well,maybe a few,its just simple numbers not rocket science.at the next bracket race you attend count the big blocks and the small blocks and the hemis gen 2,3 and see the results.all great engines,but majority rules.look just how easy and cheap it is to make 500 or so hp with a big block even using stock type heads.the expense of the gen 3 conversion is way above that alone.nobody should truthfully be surprised unless they were living in a bomb shelter for the last 3 decades....
Almost every time I go to the drag strip there is only small block mopars there. That is because I am the only person there that races a mopar.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
